DYCHE4230
Hi All,
Can anybody help....Trying to establish if I would have to change the mec on a TNS system....
Ok So S=sqr(I2xt)/k
When establishing the value of 't' do I use the characteristics of the distibutors main fuse or the main switch in the CU or I have missed the point entirely?:rolleyes:
And when establishing 'I' do I use 230v or 240v
Some direction in this matter would be most helpful.
Thanks in advance.
i think you have to use the value of the main fuse.
use 240v, that is still currently the UK energy providers output voltage, and is likely to be for a long time as they are making more money out of us this way :(
Why are you trying to calculate the size of mec when you should be using table 54.7 in relation to meter tails[largest size conductor].
Hi, I don't want to change the existing MEC if I don't have too. So was gonna check if the existing is adequate if not then I'll upgrade them as table 54.7
Thanks for your quick replies....
Adiabatic Equation
Thread Tags
DYCHE4230,
DYCHE4230,
