Discuss Aluminum wire for new mains smoke detector? in the UK Electrical Forum area at ElectriciansForums.net
I have recently replaced my old mains (230v) smoke detector with a new one from Siemens (also connected to mains).
The flexible stranded wires for the new smoke detector are silver/aluminum coloured. The same was applicable to the old smoke detector. They look like this:
I just recently found out that you need to be careful with aluminum wiring because of lose connections caused by oxidation.
The stranded wires on the old smoke detector was connected to the mains cable via a connector strip.
When replacing the smoke detector I also replaced the connector strip with some WAGO 221. But according to specs. the WAGO 221 is only approved for copper.
Are the wires for these smoke detectors aluminum or is it just a coating for actual copper?
Reply to Aluminum wire for new mains smoke detector? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi all Recently we've been having a few issues with smoke and heat detectors.. been fitting them for years and years now mostly without any...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
