- Reaction score
- 362
E54 you sure the CPC is 2.5mm? 4mm T&E here in the UK is 4/1.5, not that it affects the discussion.
A 32A ring in 2.5mm has to have 20A current capacity on all legs. Not sure where the 20A for 2.5 comes from, but in Table 4D5 20A on 2.5mm compares to 26A on 4mm (ref Method A)
Using the 20/32 ratio, if you've got a minimum 26A CCC on each leg the OPD could be up to 41.6A. Could be higher if you know the CCC of each leg is higher.
