Discuss Anyone seen these Wago connectors before. in the UK Electrical Forum area at ElectriciansForums.net
They're showing as out of stock in Europe, maybe they never were in stock.
Wago must be trying to compete with these, although I doubt Wago's price will,
Would be good if there was a small MF enclosure for a 3 way, so that it can be used if someone drills through a cable.
Could I ask what uses you guys use these for? Or rather in what situations they are more useful than normal wago's?
Used a ideal inline today . Removed old sw and put new switch connected to the d/b the line from the MCB was a bit short so used one to go into the switch and then new single back to MCB
Reply to Anyone seen these Wago connectors before. in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Been using Wagos since they came out, love them, but was wondering do you use them in poured resin submarine joints. Obviously if the resin had...
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
Hi there can you leave a wago connection joint in a wall to plastered over Evan if your using the wago connector box that wagos go on but then iam...
I found these today so ordered some as I suspect I will need to extend a few cables when doing some work soon...
