Discuss Average Cost For 2.5 kW system? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
R
R32
Could anybody help point me in the right direction to get an accurate quote for * kW grid tied STANDALONE system??
I need to know the cost of all the balance of system as well
Thanks!
Your question seems a bit vague and confusing - can you be more specific about what you're trying to achieve?
Explain what you find confusing ?
Stand-alone, in my mind, means NOT connected to the grid; by definition, it is standing alone, in the middle of nowhere, where there is no mains power.
When you speak of "the cost of the balance" - do you mean the costings of the component parts - such as the approximate sensible price (in £500 blocks) for an installation of a 2.5kW system such as:
Inverter: £1000
Roof-mounting rails: £1000
Cables, conduit/trunking, generation meter, electrical sundries: £500
10x250W Sanyo panels: £4000 (about half that cost for Chinese panels)
Scaffolding and related equipment: £1000
Day-and-a-half's wages for electrician and two roofers: £500
Miscellaneous costs - sales rep, survey, system design, bureacracy, paperwork, certification, maintenance of company registration etc: £500
Occasional warranty-repairs, occasional purchase of new tools, transportation etc: £500
VAT: £500
Then a little profit on top for the company - £500
Total cost around £10000 for a Sanyo system and £8000 for a system with Chinese panels.
Bigger systems tend to work out cheaper per kW of output; 2.5kWp might cost £10k (£4000 per kWp) but 4kWp would only cost about £12k (£3000 per kWp).
A relatively small 1.5kWp system would work out about £5000 per kWp.
*Note that these are just rough numbers; they're not 100% accurate, but they'll get you "in the right ballpark", as they say.
I am not presently associated with any solar company nor am I making any kind of offer or guarantee.
Thank you for effort it your post! As far as I am aware standalone means a system that is not roof mounted. So you could have it in your garden and it's call standalone.
Reply to Average Cost For 2.5 kW system? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
Good morning all. Before I start I am not an electrician and am relatively new to this topic. Current set up Axpert 5.5 Kw inverter, 7 x 420...
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
I currently have solar array and was going to purchase Shelly EM to monitor Grid in/out and solar production. So far so good. But I also plan in...
I'll try to make this quick... A month ago the taillights all went out, checked the fuse it was blown and replaced it. A couple day later they...
