Discuss Basic insulation _______ in the UK Electrical Forum area at ElectriciansForums.net
L
Louicardist23
Is double insulation cable necessary such as twin and earth if under automatic disconnection of supply it states that basic protection can be achieved by basic insulation only.
strange question.T/E is not double insulation.it is insulated and sheathed.
I think you are referring to double or reinforced insulation which is a means of both basic and fault protection. T/E cable is not classed as double or reinforced insulation.
No such Animal as Double insulated cable Mate, it's classed as insulated with a mechanical protective sheath.
The reason why T&E is not deemed as double insulated, is because there is only one layer of insulation between the CPC and anything else.
Insulated and sheathed singles are deemed as being double insulated.
It does not carry the Double insulated icon, ergo it's not double insulated.
Ok just to get this straight, Are you saying then that theoretically an installation could be wiring in insulated sheathed singles (double insulated) without the use of ADOS?
Thanks again
Take photos to share with us as you do it and also share the cost of the install. Nice one.
Thanks again
singles are insulated and sheathed not double insulated, but even if they were you would need some means of protection from electric shock through faults at the terminations/accessories, not just the wiring itself. you would also need to run a CPC to all points in or with the wiring system as well.
I recall basic protection being something to do with college work, like all fuse boards being boxed in being basic protection Vs mechanical protection (maybe) the locks on the fuse boards themselves to try and prevent accident, injury or death from people meddling with the things inside. I think PPE was classed as part of basic protection as well, I'm sure some genius can remind me what I'm rambling on about.
IGave you an optimistic but I'll give it a go! Basic protection in bs7671 is the primary insulation or other protection against live parts contacting anything else including yourself.
True that 1000V gloves could perform that task, but it's not really part of the installation so I'm not sure it counts in the letter of the law
Reply to Basic insulation _______ in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a fairly big property and to get power to the house, there are several metal poles with the cables running along them. I had...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
