C
charlie101
Hi all
I need to run some cabling for an external socket in a garden. The cabling will be run around the walls and will not be buried.
The cable will need to pass throught an 18" solid wall and there will be a number of turns before the final destincation.
What do you think is the best approach; Conduit or armoured cable?
Which will age better/safer ie 10 or 15 years from now?
Conduit just seems more work but I will use if it's a significantly better job.
Thanks in advance
Charlie101
Thanks in advance
Charlie101
