- Reaction score
- 1
I'm using a Wylex consumer unit to house some equipment to measure single phase heat pump performance. Part of the box is a conventional main switch and MCBs, but part of it is a din rail mounted RS485 linked three phase energy meter which is used to measure total energy, energy use by any resistive heaters, and sense whether it's in space heating or hot water mode. This all works just fine, but it involves making links from the live busbar to connections at the top of the three phase meter using 16mm cable.
I've made these busbar to wire connections so far by using MCBs, but is there any other connector available that would make a tidy job of this ?
Cheers, J/.
Cheers, J/.
