P
Patch
Evening chaps. Long time reader first time poster right here, big fans of your work and all and I'm hoping to call upon your collective experience and might with a rather large job I seem to have "lucked" my way into.
The property is a grade 2-star listed building in the fair county of Rutland. In total there are about 22 rooms (subject to the whim of the owners), 5/6 bedrooms, 3 bathrooms (2 e-suite), drawing room, study, lounge, kitchen, dining room blah, blah, blah the list goes on.
The main house was last refurbished (read: bodged) in the late 50's and has fallen into a state of disrepair in recent years. The job started at the start of April and I'm now finding that we're ready to start carcassing. I've been given no wiring specifications, I've had to push for a lighting design so I'm doing most of it off my own back. Of course, I've never tackled anything on this scale
My main problems are:
** The list of final circuits has spiralled to somewhere in the region of 20. Mostly lighting. Five are interior (two upstairs, three down), one for exterior security a second for exterior decorative. Power has similarly be split into five circuits (again, two up, three down) alongside which are round pin 5 amp sockets (for lamps) of the same arrangement and finally a dedicated fridge/freezer and cooker feed (reported to run off a 13 amp plug, but I figure only just). Oh, and an immersion back-up if the bio-mass boiler fails. Questions? Good.
Is this excessive? On one hand it makes good sense, on the other... well, 20 is a lot!
Most of the fixed lighting will be ELV in various forms (LED, halos, CFTs) with one or two decorative pendant fittings. Without knowing exactly what's going where, is there a better way of guestimating other than the old "assume 100 watt per fitting" rule of thumb? At the moment that suggests 10 amp breakers which when it comes down to it, will probably be way OTT.
I'd like some clarification for the 5 amp round pin sockets. My instinct would be to set them up as a ring main on a 6/10 amp breaker with 1.5mm T+E. Is this correct?
Is having enough ways as simple as running two CCU's and feeding them off henley blocks?
**The house will be heated with hot-water over (yes, over) floor heating. This means that anything under floorboards will be inaccessible once the heating is in place. It has been suggested to me that a gap around the walls could be sufficient to run cables and leave them accessible in a worst case scenarios. 6mm thickness of ply provides the FFL. Is that sufficient mechanical protection (bearing in mind there'll also be a skirting on top of it)?
** Even with diversity, I'm looking at a maximum demand of around 150 amps. Do I just need to get the distributor to upgrade the supply?
Right, pub o'clock! Thanks in advance for any insights! I'm sure I'll come upon more stumbling blocks.
