Discuss Burglar Alarm Speech Dialler in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Dru
I have got an Informa speech dialler that I need to install on Veritas 8 alarm panel. I am unsure on the connections.
Has anyone installed one of these or something similar?
Can anyone help? I can post pictures if required
It seemed to easy to be right for some reason. I thinks it's just because I've never done any work on alarms before.
Thanks tazz. Appreciate it mate
no problem....you can also used the inhib terminal to sw+ if you dont want the dialler to call when panel is unset, as in PA, or testing bell
No sorry connect as well if required, all this does is stops the dialler ring out, unless panel is armed/set...
12v and ov to panel aux 12v and 0v.....ip1 to bell B terminal
Hi taz. I have a veritas r8 panel and need to install the imforma speech dialler. Would appreciate if you tell me about the connections. I.e do I have to connect all the IP1, IP2, IP3 and INH? Thanks
Reply to Burglar Alarm Speech Dialler in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Hello all I hope you are well. I had a new Alarm Panel installed in January and all was working well until I got a new Consumer Unit installed...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
