- Reaction score
- 67,272
he's on holiday/his granny's died/he's in rehab/emigrated/sectioned.........Why hasn't the electrician, who will be signing off your work, told you the best option on how to do this?
Discuss Cabinet lights from ring or light circuit? in the UK Electrical Forum area at ElectriciansForums.net
hope he doesn't chance it. .Electrician will have access to every switch/socket every cable and will be easily able to carry out tests. The same electrician will also chance my CU.
Because one man opinion is not always the best option The forum allows for discussion and other point of views.
he suggested from ring.
take any negative posts with a pinch of salt, mate. you seem to be trying to do it right and good luck with it. me an d pete usually get our kicks from visiting the local maternity ward and swopping tags on new borns. but we've been banned from there. new source of merriment required.Because one man opinion is not always the best option The forum allows for discussion and other points of view.
it is for 'er indoors when it's her turn to wield the hammer.Try nailing your dangly bits to a wooden table.... That's loads of fun...
Are you going to connect from the ring final circuit to the fcu using your 0.75 cord.
You don't have that authority though. I hereby declare the thread still open.Thread is closed.
Reply to Cabinet lights from ring or light circuit? in the UK Electrical Forum area at ElectriciansForums.net
