Discuss Cabinet lights from ring or light circuit? in the UK Electrical Forum area at ElectriciansForums.net
Are you going to connect from the ring final circuit to the fcu using your 0.75 cord.
Don't worry mate. His electrician has told him how to do it. They are also checking it, so what could go wrong.
Reply to Cabinet lights from ring or light circuit? in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
