Discuss Cable size for scaffold hoist in the Commercial Electrical Advice area at ElectriciansForums.net
B
BarnyJ
Hi,
I need to replace a cable that is used at a scaffold yard to test the hoists. They currently have a 6mm cable installed but they say that when they try to test their biggest hoists the cable doesn't have the capacity and the hoists wont function properly. The information i have about the largest hoist is:
3ph
400/50hz
63/32A (TBC) female socket (5pin red)
2 x 8kw motors
180A startup
38A running.
what i need to know is do I need to size the cable to carry the whole 180A or do i need to size the cable for the running load of 38A and have installed a D type breaker for the spike in current at startup.
Having looked in BS7671 I can see that 6mm is adequatley big enough for the 38A running load.?
Any help with this question woould be greatly appreciated,
Ta.
6mm should be adequate. the start-up current is for very short duration. depending on the length of the cable, volt drop could be the issue.
Reply to Cable size for scaffold hoist in the Commercial Electrical Advice area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
I brought a semi professional falcon cooker and currently my property doesn’t have any high power cooker supplies, the cooker draws about 11.5kw...
