Discuss Can anyone help me identify the 3 speed coloring of my cooker hood connection. Please look at the photos in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Hi
Can someone help me please?
I got a new cookerhood motor and I know the color coding for different speeds. But I need to find out the existing speed color coding to to connect to it. Could someone look at the photos and tell me which color is which? Its a 3 speed setting. Thanks in advance.
Did you look on the motor itself? There might be a label with speed wiring indicated on it.
If not, with the power isolated I'd remove the wiring from the switch and use a tester on ohms scale to establish which connections are made across the switch for the different speed settings. This can be done as a live test but it's dangerous and not recommended unless you're competent and with a risk assessment first.
Be careful messing with electrics when you're unsure about what's going on! :)
Could you post a picture of the old and new motor information labels and their wires?
Motors of kitchen range hoods S80 Fime Best EB40MTA - https://repair-and-servise.com/stati-i-izobreteniya/engine-motor-extraction-s80-fime-best-elika-eb40mta.html
I think the original motor in the cooker hood was a FIME PSC motor similar to the one at the end of the link. The wires to it are black, blue, gray and white - red is unused and not brought to the slide switch. This is what we see connected to the slide switch.
This motor uses the four 'horizontal' run windings as an auto-transformer to energise the auxiliary winding (vertical) via the capacitor. See the motor wiring diagram at the bottom of the diagram at the end of the link.
The slide switch connects the feed L and N as follows to be read in the order Blk Gry Whi Blu:
Off
Fast L N X X
Medium X N X L
Slow X X N L
where X means not connected.
This preamble is to explain why it is important to establish how the windings of the replacement motor are connected and to which colour wire before connecting it in place of the old one - otherwise some damage may be caused to it. The new motor needs to be suited to the way the slide switche connects L and N to it for the three speeds.
Status
Reply to Can anyone help me identify the 3 speed coloring of my cooker hood connection. Please look at the photos in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Hi there, wondering if anyone can give me some advice please. In my kitchen I have a cooker switch with a plug socket which I believe is on a...
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
