Discuss Can i take a Fused Spur from a 45Amp Cooker Point in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dave0098
hello every1, i want to put a extractor fan in a shop kitchen, the easiest method from looking at the job would be to come off the cooker switch with a fused spur and power the extractor fan this way. its only a small extract fan, ive not bought it yet so i would say its no more than 1-2 Amps load.
cheers Dave
personally i class cooker point as dedicated circuit, that has been calculated for its demand and so wouldnt feed from it, not sure where regs stand on this though, just my method.
If its just anything up to say a 9 inch xpelair or the like it is going to be of no consequence to the calculations (if any were done) to the cooker circuit but its not really the done thing.
so from what i gather aslong as the fan dosent compramise the cable current carrying capacity im ok. but i cant really find a answer in the regs which says, "this is not to be done". from my calculations the cable will be ok upto 44Amps. the cooker is about 25Amps thats well under the 44Amps calculated. if the cooker was closer to the maximum current carry capacity of the cable then yes i would say its maybe not safe to take a spur from it. but i think theres plenty to play with there for an extractor fan circuit. after all some cooker switches come with a 13Amp socket outlet.
thanx for your replys, its good that we can have opinions from someone elses point of view which some might not have thought of or taken into acount.
cheers Dave
No one is arguing with you marks, but as cooker is dedicated circuit for that appliance then the norm is to leave it alone, also as sparkswillfly stated , at home i wouldnt think twice but for a customer i wouldnt do it mainly as its not common practice.
similar to light switch in bathroom, can it be fitted inside the bathroom - yes, but its not common practice
cheers Dave
Just run it off a lighting circuit.
Hi Jason
Nice question the answer is 2.5mm can carry 27amps and the spur-off can only generate 26amps maximum. As a socket has its own local overcurrent protection and it would not be probable for both sides of a double socket outlet (if fitted) to overload at the same time and if this did the cable would take the short duration.
Regards
So basically a 2.5 spur from the cooker point would be ok, especially if it was only powering an extractor.
Hi
Yes, I had this debate with one of the inspection councils many years ago and he suggest for this you could even use 1.5mm, but should use larger just incase someone puts a double socket on the spur, this was before part P when incompetent people worked on their own installation ha ha. I believe from the science of it the current will not divert from the direct path to the cb so the load current will not enter the smaller cable.
Please correct me if I have got this wrong.
regards
now i can understand some of you saying the cooker circuit is a dedicated circuit, but like i said in my last post, some cooker switches come with a 13Amp socket outlet on them. so thats not part of the dedicated circuit, because theres nothin to stop some pluggin whatever they like into that outlet. im using just a cooker switch with a fused spur thats going to be rated at something like 5Amps, dnt really see any difference.
and to Electro i always try and use the same size cable to the supply side of the fused spur as from where im spurring from.
Dave
You are absolutely correct Dave, however, the circuit should have been designed taking into account the extra loading the socket puts on the design current of the circuit.
Reply to Can i take a Fused Spur from a 45Amp Cooker Point in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
DIYer question. I have a 32 amp supply going from consumer unit in garage to kitchen. It supplies an induction hob only. The cable is easily...
Hello all. I have just bought my first house but it needs a bit of work. I am re-wiring it and I've found the conservatory ring has been spurred...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
