Discuss CAn I wire 12v downlighter transformer into dimmer circuit? in the Lighting Forum area at ElectriciansForums.net
Hi all. I've bought couple of LED tape kits which come with a 3pin 12v transformer. one of them is now wired into a simple circuit which is a single on/off switch and works great.
the second set is to go into another room, again single switch but this time it's a dimmer not toggle. The kit is not labelled as dimmable. Am I ok to use it on a dimmable circuit?
Thanks guys
Thanks guys
Only if the driver is dimmable.
As above it's unlikely to work unless it's specifically designed as dimmable. You could just try it, it's unlikely to damage anything, most of the time you'll just get flashing or flicker if the drivcer isn't dimmable.
Reply to CAn I wire 12v downlighter transformer into dimmer circuit? in the Lighting Forum area at ElectriciansForums.net
I have installed a number of 120v smart light switches and smart bulbs which I have set up on a schedule via an app. I would like to add another...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Is it possible for a single dimmer switch to control two circuits, one which dims and the other which is a discrete on/off? I would like to be...
