- Reaction score
- 1
Hi there,
I'm helping on a large industrial site upgrading the existing cctv system to HD however i can't get some of the new camera's to work! Do HD IR cameras take much more power to operate? should a higher spec power supply be installed? I suspect that the cable runs are too long causing decreased power getting to the camera as they work fine if i plug straight into DVR? what is the usual way of combating this problem? My wiring is shotgun coaxial with runs unto 80M. Should i consider installing local power supply?
I'm using COP HD-SDI 1080 12v DC 380mA dome camera's with an Inspire DVR.
My power supply is a 10way 1A per channel supplying 10 cameras.
Regards
Regards
