K
Kieran94
Hi all ,
Well most of you experienced sparks will probably think this is a stupid question, however i have got a feeling something will go wrong.
My dad is changing the sockets/light switches from plastic to metal - which isnt the bit im worried about. The switches are wired in T&E and the cpc is running to the back box(metal). He was planning to take the cpc out of the back box & put it in the earth terminal of the switch. Can that be done?
Also with the plug sockets, they are double sockets and on the plastic have have 3 live, neutral and earth wires going to each terminal in the socket(again im not bothered about this) but then when we look at the metal socket there are 2 earth terminals for the top pin of the plug on each socket, how will he supply both the earth termials? do they both need to be supplied?(i think they do in my opinion).
Thanks for reading & i hope you can understand this
Kieran
Kieran
