Discuss Code based rewiring requirements for home renovations. in the UK Electrical Forum area at ElectriciansForums.net
cksa101
Planning a home renovation where about half the house is being significantly altered (moving walls etc). All of the wiring, outlets, fixtures, and switches in those alteration areas will be replaced and a new electrical panel will be installed. The other half of the house just gets new outlets, switches, and fixtures (plus fresh paint and a little floor refinishing).
I am unable to find any code based requirement to replace all of the wiring in the portion of the house that only gets fresh paint etc. However, an electrician is telling me that there is a code requirement to rewire the entire house.
Are any of the electricians here aware of any requirement to rewire an entire house based on square footage being altered as I've described?
Sounds a bit extreme to me but this is a UK based forum which does have a section for American queries which I have moved it to so hopefully one of our US members like @Megawatt will pick up on it.
Sorry for the delay but you can rewire what you want to and DO NOT have to rewire the whole house. Good luck
If it complies with BS 7671 I can;t see a problem
Sorry for my premature reply Mate forgot to note you are an American Cousin apologies
Reply to Code based rewiring requirements for home renovations. in the UK Electrical Forum area at ElectriciansForums.net
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
Just bought an old house (about 30-40 years old) with a separate shop building. I am in the process of replacing old fluorescent fixtures with...
