Discuss Conduit install outside in the UK Electrical Forum area at ElectriciansForums.net
Hi all
PVC Conduit install outside, for a socket and this socket is supplying a lazy spa hot tub plug and play thing. Conduit is top entry into socket, I can see they have used conduit cement at joints and also installed a flat plastic IP washer at the top entry where the conduit adaptor enters socket. Also socket is IP 66. With it being IP66 would this top entry compromise the IP rating of the socket or not have seen a lot of light fittings coming top entry that eventually let in water but they have never installed IP washers ? Replies will be much appreciated
should be OK, but drill a drainage hole in the bottom of the socket box.
where possible use side of bottom entry when outdoors , but i wouldn't change something if i come across a top entry outside as long as were no signs of water getting in
External vertical conduit and cable, as we know, should always have a low point prior to entry of a junction box or outside socket, this can just be done with plastic conduit by a bit of manipulation, but the better fix is bottom entry as suggested by SS above.
Reply to Conduit install outside in the UK Electrical Forum area at ElectriciansForums.net
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
