Discuss Crimp Insulated Yellow 6mm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
simon63
Just double checking that these are the right crimps for the job,
My new cooker needs to be connected by 6mm eyelet crimp connectors the ones I have found are Cable size: 4-6mm². Imax: 48A, am I correct in thinking that these are rated to 48amps and wound be fine on a 30amp double oven cooker?
Hi Simon: They should be fine as long as you get them from a reputable Electrical wholesaler, unfortunately there's a lot of cheap copy's around. You need to crimp them with a Ratchet crimper as well to give you a good connection. Don't be tempted to use 1 of the cheapy hand crimpers.
Yellow ring crimps Simon, correct. But no good unless you have a proper ratchet crimper. Otherwise you would get a loose connection. Loose connections = fire
One of these.....
images
Applied with one of these.....
images
Obtained from a reputable wholesaler
persuming your cooker is fed by a 4 or 6 mm cable, then yellows would be correct. The earths more than likely to be 2.5mm2 tho.
Thanks for the replies I have ordered them from screwfix I did try to ring them but they are closed for the holidays, I have a 4 way crimper/stripper that crimps 1.5 2.5 and 6m, I think I will splash out on a Ratchet crimper after all you cannot have to many tools
Thanks again for the help and have a happy new year
Your welcome Simon & your right about the tools. But don't tell my missus i said that lol.
By the way: Merry Christmas to you.
Reply to Crimp Insulated Yellow 6mm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hi, Just looking for a bit of advice here. I am considering swapping my existing 4 burner gas hob for a Bosch induction one. I am not proposing...
5K
Hello everyone, I am no domestic electrician but I do work as a designer in the railway, low voltage signalling circuits etc. My question concerns...
