- Reaction score
- 6,956
No you may not legally remove the cable,unless you can return the premises to the exact condition they were in before you started.Typically this can mean for example if you have drilled holes in the brickwork to get the cable in then you must remove said bricks and replace them with bricks that match the original,you may not fill the holes with mortar as they were not filled with mortar before.This may sound petty,but that's how bad it can get in a court case.The BIG mistake you made in this situation is doing the work without written authorisation.Basically in a court of law a verbal agreement isn't worth the paper it should have been written on.I bet I know what's happened here,there has been some misunderstanding regarding the cost of the job and now the guy doesn't want to pay,the tenant shouldn't have to pay as I would assume that he's renting a property that includes utilities,gas,water,electricity.You appear to be between a rock and a hard place,however I would strongly recommend that you go down the legal route or you could be the one in court.
Sorry, but that is bo$$ox. In a small claims court, the landlord wouldn't have a leg to stand on. Been there....done it. A verbal agreement IS a contract.
