Discuss Determining if wire is neutral in the DIY Electrical Advice area at ElectriciansForums.net
dave-c
My wall box has two switches with two black wires connected to each. It also has four white wires on a single nut, not otherwise connected. Are these neutral wires? If not sure, how can I test?
They are almost certainly neutral but a continuity test will verify.
Reply to Determining if wire is neutral in the DIY Electrical Advice area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
