Discuss Dimplex Plx150e installation in the UK Electrical Forum area at ElectriciansForums.net
I want to install a Dimplex 150e panel heater. The instruction manual states categorically that "Products that are supplied without a plug are for installation into the fixed wiring of the property, via a suitable double pole switched fused spur". As it is only 1.5kw I don't understand why I can't just use a 13amp plug. Can anyone tell me please?
A plug suggests a portable appliance.
this is fixed to the wall I presume(?) so not portable.
same thing with a gas boiler, could run off a plug, but everyone uses a switch fuse
Yes it is on the wall. I still don't see the logic of a switch fuse and It would be easier for me to use a plug, but if everyone uses a switch fuse I'd better do the same! Thanks
13amp plugs are basically for use on portable appliances
The heater if fixed won't be moved so can be wired direct to a DP spur
Thanks. So despite it being unconventional, as I already have a socket by the heater and I don't have a DP spur, presumably it's acceptable for me to use a plug (despite the manufacturer's instructions)?
Reply to Dimplex Plx150e installation in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi. I've been asked to install a Dimplex qm150 storage heater for a customer. There is a suitable existing supply for the off peak element...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Looking at instructions for installation for Baumatic BHI300 it requires a 20A Double pole (3mm separation) switched fused spur, I quote pretty...
