J
Jordan Reed
Hi guys!
First post here but REALLY need some help!
I want to use an extremely bright LED or very small bulb and a laser module in the same circuit with a 4.5V supply (3x AAA)
I would like to use a toggle switch to operate the unit but use two other switches (in parallel I assume) to select light on/off and laser on/off.
I have an idea of the bulb and laser module was thinking of using:
bulb: Replacement Maglite / AA Bulbs Twin Pack | Maplin
laser module: 1mW 3V Red Laser Module | Maplin
Now the main concerns are:
1- Can my supply run this?
2- Will i need to use resistors in the circuit?
3- How would you suggest working the switch? (note: i am VERY limited with space)
4- Are there any better alternative components to those i have listed (note also: power supply is not changeable)
Thank you SO much in advance at any help I may receive.
Jordan
P.S. If you would like to know the project then I will tell you- It's no secret just not particularly easy to explain I expect!
Here's a little preliminary sketch of what I have came up with so far... I apologize it is no Sistine chapel!
http://i.Upload the image directly to the thread.com/bLszdT4.jpg
Jordan
