Discuss Do i need to re-test? in the Canada area at ElectriciansForums.net
DanBrown
Ive just been asked to sort out the mains distribution to do with a commercial restaurant. The work involves re-configuring the mains tails as their is 3 distribution boards fed from it and is a bit on the dodgy side. My question is... If i change the mains tails, does that mean the entire place has to be re-tested?? i.e. all three boards...
I would say so, but just need a confirmation.
Thanks Guys
Dont see any reason why you need to retest the whole installation.
Then again, i suppose your Zs may be different on the circuits.
Depends how much work you have to do or if it literally is just the mains tails.
Maybe do a before and after on the circuits and check against existing test results?
Thanks for that Jase!.
Hey mate.
I'm guessing the tails are only short and not a sub-main??
I would say that all you need to do is check the Zs and PSCC at each DB after you've changed the tails and this should be sufficient.
On NIC test forms there is a line just for the meter tails so I would say that you could just fill this in and your covered.
In the extent box obviously just put upgrading of meter tails only.
For peace of mind you could measure Zs at the end of a circuit on each board
Cheers:D
Reply to Do i need to re-test? in the Canada area at ElectriciansForums.net
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
I’m just finishing my L2 2365 at college in the evenings and plan to do the L3 2365 with the same college as an evening course. However I would...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
