Deleted member 9648
A recent minor works on a small electrical supply on a playing field revealed a TNCS earthing system. Setup is a DNO head feeding a small DB with a 30ma RCD main switch and mcb's feeding a couple of 16/32a sockets and 13a sockets used for public functions and small fairground supplies. The local authority agreed to converting this to a TT (but declined the addition of a 100ma S type main switch and RCBO's on cost grounds).
So today in 30 degree heat I arrived with electrodes to do the conversion. First issue was that there was already a disconnected rod in the ground,in poor condition but presumably it had been TT at one time. Anyway a new 5/8 rod went in with a pit with some difficulty and I optimistically got the ELI tester out.....850 ohms! Coupled on a second rod and spent the best part of the next hour getting down 8ft....testing as I went it gradually came down and we ended up with 80 ohms.
My question is to everyone is would you have left it at that as I did or would you have gone further? If further how far?.....I guess a third rod and a lot more time might have got it lower....perhaps even as low as the magical 15 ohms, which seems to be the trigger for mutual congratulationary back-slapping from the 'you cant possibly rely on an RCD' clique on here.
This is not intended to be another full on Ra debate....I am just interested in what the good members of this forum would do with the installation.....Honest answers please!
