Discuss Double outlet ev chargepoint for B&B in the UK Electrical Forum area at ElectriciansForums.net
I am an ozev approved installer and have installed a couple of single home wall charger units but have a requirement for two outlets at a parking spot with a b&b, for staying guests; has anyone any experience of a multi-outlet system or can recommend which units to go for? or would two singles be a better option? There appears to be a dedicated 63A supply available, on a separate phase to the property..
Reply to Double outlet ev chargepoint for B&B in the UK Electrical Forum area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I have seen recent changes that require (most) EV chargers and solar systems to be fitted with a type B RCCD. I work with power semiconductors...
Hi all, Newly qualified electrician here who is in the process of re-wiring my own property. I have recently converted my old CU (if I can call...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hi, I'm looking into solutions for someone wanting potentially two ev chargers and wondered if anyone here has had experience with this. They...
