Discuss Electrical Installation Certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
raylewis
Could you guys tell what you would do ?
What if you are called to complete another Electricians work for whatever the reason
and then you have to test and certify, what would you do ?
What cert would you issue ?
Hasn't happened to me yet but it will one day
Ray:confused:
Hi Ray,
If you are finishing someone elses work, then you need to contact the LABC and inform them of the situation.
In most cases they will accept a PIR instead of an install cert.
If I were called to complete someone elses work, unless there were reasonable and verifiable reasons for the other spark to have left, I'd probably do a PIR before I started. I'd hate to land myself in a situation where bad-feeling between client and spark may have left an installation unsafe without checking what I'm getting in to.
Hey.
A lot would depend on how far the other spark had got. If it was early stages of first fix then chances are you could inspect what he had done and either re-do if it was bad or accept it and take it over as your own
If it was further along i.e 2nd fix then a PIR is the only way to go.
Cheers.
on the electrical installation certificate (the mulitiple signature one) you as the inspector ,tester have your very own box to put ur paw print in ,,, and the sparky who wired it has his/her own box for his/her paw print so does the designer ... on the first page it also asks you for description and extent .that way you are covered,
but if you did do the design , install etc then theres the short Electrical Installion certificate with jus the one paw print , hope this helps
You cannot issue an eic for this work Building regs part p require the installer to be registered or a notification having been made to them
If you issue an eic you are efectively taking on the resposibility for the whole of the install,because you can only notify work carried out by your enterprise
Unless it was visable for inspection then it would be taking one big chancer
Most would if they had the scenario Contact building control ,give them the situation and offer a pir
Reply to Electrical Installation Certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Not sure whether this is the right context or even forum to mention this, but I’ve recently been offering out myself to a friend to help get his...
I am seeking a job as an electricians mate / improver / labourer around South Yorkshire. I am based in Doncaster, i have a uk full driving licence...
I note that in answer to another EV Charger question a member suggested a 40A breaker would be preferred to a 32A because of many hours at...
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
Hi guys I’m at one of the funny times in my career where I can’t decide on what I want to do. I’m wondering if one of you experiences folks can...
