Discuss Extending Shower Cable in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
I need to extend a shower cable due to building work making it 6 inches too short.
The cable runs through a single storey extension so no access above to put junction box which need to be accessible.
The existing wall where the cable runs down is having a "mini" partition build in front of it which the shower will be fixed to.
Is it acceptable to put a junction box on the exsting wall directly behind shower and label the consumer unit of its location.
That way, if there was a fault or needed to be inspected, the shower could be taken off the wall and access the junction box through a cut out in the plasterboard.
Why don't you take the short cable to a pull cord switch in an easily accessable position and then drop a new bit from there to the shower?
There's no access above and the cable runs straight down to shower so the only accessible place would be directly above shower.
Reply to Extending Shower Cable in the UK Electrical Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi, I have a book on domestic wiring which says that everywhere there is a change in current carrying capacity along a circuit there must be some...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
