M
Mark.W
Evening chaps
Does anyone know if you can get alternative leads that will fit a fluke 1652. Preferably a set similar to the metrel leads where the crocodile clips plug onto the probes?
Regards
Mark
If the Metrel leads have the same size plugs as the Fluke ones, then they should push straight into the Fluke.
As far as i am aware all the leads irrespective of manufacturer are the same size on the plugs that fit into the tester, so you should be able to buy any. Watch out for cheap ones though, i had a set off ebay and they were 4 ohms resistance and only a meter long!
Fluke 1652
Electrical Tools and Products
Mark.W,
SirKit Breaker,
