Discuss Forget screws, this is the new way to secure back boxes to walls in the UK Electrical Forum area at ElectriciansForums.net
123
Silicone! And lots of it.
Not a screw in sight.
It’s got “Kev the kitchen fitter” written all over it!
(Not me by the way!);)
Certainly has, this was in the kitchen of the property and it's a total shambles.
Bigger issues include one leg of the rest of the apartment ring and the dishwasher circuit being arse about face (so ring is across 2 MCB's, as is Dishwasher circuit). A couple of under cab lighting JB's just buried in the plaster. A couple of spurs relocated, in choc blocks and tape and then plastered over.:(:(:(
its almost as bad as when the apprentice gets let loose with the intumescent sealant on the new builds. they have to maintain the fire rating between flats and boy do they use some, you go along afterwards to change a socket and the wires are literally hidden in a lump of sealant where the stuff has sunk or moved with gravity after they have been and gone. they put it in and over every little void within the hole and around back box. I hate the stuff
Mr Percyprod should observe this thread - it's another example of someone who thinks electrics are a doddle and the resultant mess, although it can be much worse than this.
Are the walls "tanked"
I can see where you are coming from, penetrating the tanking with a screw, it would have been a way around it.
But no they aren't, it's not that old a building either (early 2000's), breeze block & cavity walls. Also all the pictures are on internal walls also.
Reply to Forget screws, this is the new way to secure back boxes to walls in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
I am getting ready to install a new wall oven that's about 4 ft closer to the panel than the old stove. I have about 4 ft extra cable with the...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
