Mar 21, 2013
456
348
138
Rotherham South Yorkshire
United Kingdom
Hi guys just wondering if anyone would be able to price check this four bed rewire i'm currently quoting at the moment. It's out in the sticks about an hour from where I live. I've come in at about £4800 but it seems like a lot of work.
All walls are rendered breeze block and the downstairs floors are concrete. All fittings would be click mode & white pendants unless customer buys there own.
Garage
X1 Double socket
X1 Single socket for door
X1 Light switch
X2 Double 5ft fluorescent lights
Utility
X2 Sockets for appliances
X2 Switches for appliances
X1 LED downlight
X1 1 2g Light switch (downlight & outside light)
Rewire existing outside light
Dining Room
X1 Double socket
X1 TV Point (high up)
X1 Socket (for TV high up)
X1 Data point (for TV high up)
X1 2g Light switch (dining lights/kitchen 2-way)
X1 Centre pendant
X1 1g Light switch (outside light 2-way L/Room)
Kitchen
X1 Socket for fridge
X3 Double sockets (worktop height)
X1 Extractor fan supply
X1 Cooker point & isolation Switch
X1 Under cupboard lighting feed
X1 Socket low down
X1 TV Point
X8 LED Downlights (switched in two sets of 4)
X1 3g Light switch (kitchen lights 2-way, under lights & sitting area)
X1 Interlinked heat alarm
Living Room Off shot
X1 Light switch
X1 Centre light
X1 Double Socket
Living Room
X6 Double sockets
X1 TV point
X1 Telephone point
X1 Data point
X1 Centre light
X4 Wall light feeds (wall lights not supplied)
X1 2g Light switch (centre light, wall lights)
X1 1g Light switch (outside light dining 2-way)
Downstairs Cupboard
X1 Light switch
X1 Light
X1 Double socket for router
X1 Telephone point
(Data cables to be run here & terminated, all wiring & accessories to be surface mounted)
Hall
X1 Centre pendant
X1 3g Light switch (hall light, landing light, outside light)
X1 Double socket
X1 Interlinked smoke alarm
Downstairs Toilet
X1 1g Light switch
X1 Centre light
X1 Boiler supply
X1 10way RCBO Consumer unit Inc.
Bonding water & gas main
Landing
X1 Double socket
X1 2g Light switch (hall Light, landing light)
X1 Centre pendant
Main Bathroom
X1 Centre light
X1 Mirror light supply
X1 1g Switch (outside bathroom)
X1 Extractor fan isolator (outside bathroom)
X1 Extractor fan with overrun timer
Front Bedroom
X1 Alarm supply
X1 Light switch
X1 Centre pendant
X1 Double socket
Back Bedroom
X1 1g Light switch
X1 Centre pendant
X2 Double socket
Side Bedroom
X1 1g Light switch
X1 Centre pendant
X2 Double sockets
Master Bedroom
X1 1g Light switch
X3 Double sockets
X1 TV Point
Chase existing alarm cables in to wall
Master En-suite
X1 2g Light switch (Downlights, fan)
X1 Extractor fan isolation switch
X1 Mirror light feed
X1 Shaver point
X3 LED Downlights (including loft insulation guards)
Loft
X1 1g Light switch
X1 5ft fluorescent light fitting
X1 TV amplifier (Terminate TV cables here)
X1 Double socket (for TV amp)
Other
· Reprogram existing alarm panel & replace back up batteries.
· Patch up around new accessories & channels
· Install feed for new outside light at back of property switched from L/Room & D/Room. Fitting not supplied
Thanks, Tom
Is the house unoccupied and empty?
Sorry forgot to mention that it was unoccupied
I think you are shy too , especially if the up floors are not floorboards.
As above , it is unoccupied , but is it empty?
Always difficult without seeing the actual site, but i recon you are a grand light on that quote.
PS Yorkshire. Is there electricity there now, blimey??:D
Upstairs has floorboards which makes life easier but didn't get chance to see the loft as it was a dark night when I went over. I'd two coat chases I think. The house is empty and carpets are up etc. There's a few walls which are coming out and one or two extra being added downstairs.
It's in Derbyshire so might be taking some overnight stuff and a stove incas I get snowed in haha
I'd come in a little higher than that. without seeing the job I'd be looking at around £5300 as a rough estimate.
I've just had a quick browse through and come in at around £5600 that doesn't include patching up. As a rough guide that's about 21 one man days work IMO and that's with no patching up.
Yh minimum no. Of Sockets in bedrooms might not be met lol, nearly 100 points
Reactions: Octopus
This jobs just grown and grown with the customer wanting chrome fronts throughout the property and a sh*t load of other extras. Great job though, I've really enjoyed it up to now. I must admit, it's quite tough when your on your own. The runs have been a bit tricky as there's a lot of steel beams to work around but I'm just about on top of it now. 15 Days in with a good temporary second fix. I reckon there's another 5 or 6 days with all the niggles etc
Music on and enjoy lad , get in the zone ....
Reactions: J.C.E
Me electrical mr
United Kingdom
four bed rewire price check
Electrician Talk
tomspark93,
growler,
