Discuss French Heating Systems in the UK Electrical Forum area at ElectriciansForums.net
J
jtimbers
Hi guys,
does anyone have a wiring diagram for french heating systems? I know they use a lot of electric heaters over there but I need a standard gas boiler/valve set up. Will it be the same as a British one?
Thanks in advance!
Hi guys,
Thanks in advance!
Hi
I lived in France for 6 years and built my own house there, I found a website that told me electrical, and heating
french norms. You can ask your question and you will get replies, go to Frenchentree.com, click on renovation,
under contacts on the left at the bottom click on building and renovation forum you will see forum for heating and plumbing
Hope this Helps.
I've moved this to the Non-UK Electrical forum for you, it may attract the attention of members with specific knowledge of EU systems better in this forum.
Hi guys,
Thanks in advance!
I lived and worked in france for more than 20 years, 13 with my own electrical and renewables business. Not sure I understand what you need to know? Is a standard gas boiler something you are linking to the mains gas ( called town gas/ gas de ville ). Valve? Any wiring for any boiler will be a seperate spur from the CU, NOT a fused spur from a localised supply.
Please contact me direct via the forum for the info you need.
Reply to French Heating Systems in the UK Electrical Forum area at ElectriciansForums.net
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
