Search the forum,
Discuss Fuse characteristic in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
Skyba
Hi, I'm currently studying for both my 2394 and 2395 exams and I've been thinking of scenarios to test myself of certain theories, I thought of one where a garage board would be fed with a 13a fuse spur with only a 1.5mm armoured buried under ground. So I started thinking about fuses etc and I know the cable will be protected by the fuse due to the maximum capacity of the armoured but I was looking into the spurs breaking times and I don't know if I'm being plain stupid or not but I cannot find the characteristics of a 13a fuse in appendix 3 of the regs anywhere.
Am I being stupid, I'm sure it exists.
Reply to Fuse characteristic in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Once again I am using the Engineering chat as I think my question is more theoretical rather than 'diy advice'. If I am misusing the forum...
  • Locked
5K
Ringmain fed by 32A mcb on split board protected by rcd,I'm spurring of ring feeding a underfloor heating system rated at 9A ,I know I can fit a...
