Discuss Fuse needed in the Electrical Tools and Products area at ElectriciansForums.net
P
peteelecs
Hi
Does anyone know where I can get a fuse 1A/1000V High Energy Fast Acting 6mm x 46mm its for a cable tracer no one seems to stock it
Reply to Fuse needed in the Electrical Tools and Products area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Merry Xmas!!! My Nobo electric heater has stopped working. Everything seems fine but there is no continuity in a part that I believe is a safety...
Hi I need to find a suitable replacement for a DU/C GFE 10A 250V (PF) - 10A fuse it needs to be glass fast blow Any advice would be appreciated...
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
Hi all, I'm wondering if anyone might be able to help. We have a fused switch that controls 4 LED lights next to a power socket which have both...
