Discuss fuseboard change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gregorabbott
hi,new member here. when changing a fuseboard should i test and issue a test certificate when doing this job or only if the customer asks for one? and should i price the changing of the fuseboard and testing/certificate seperately?
you must do an EIC for the CU change, if you are to conform to regs... customer doesn't have a choice in the matter.
You have to issue a test certificat and test the installation , this type of works also come under Part P and is notifiable to the council , also this type of work should only be carried out by a competent and approved electrician
not a wind up. i know you are supposed to do a full test but when you tell customers this and give them a price they sometimes run a mile! i have been on websites looking at what people are quoting for fuseboard changes and there is no way they can be doing this properly with the low prices they are quoting! some prices were lower than 140 quid! i was just double checking! i have my 17th edition. not part p though since that does not apply in scotland!
Oh dear:eek:. Prepare to be shot down and burn. Sorry mate, If you are a qualified and/or experienced electrician you wouldn't be asking this question. And this is not an electrical job to undertake if you are trying to cut your teeth in this profession. It is not something "to have a go at" either if you are an electrician but don't have the experience. And its a definite NO NO if you are a DIY'er without the correct test instruments.
Cheers..........Howard
Blimey.... what websites are those then ? I dread to think what sort of job they got !!!
perhaps this job is one where somebody he knows with more experience can oversee him doing the job. that way he will learn more, practically, than any amount of college course.
just to clarify on here that i am an electrician. i change fuseboards almost every day at work. i work in rewire squads. the way we work is that the rewire squads go in and rewire/upgrade the house then the testers come in and do the required testing. the reason i posted this question is that i am not 100 percent certain on the certification side of things as i do not have my inspection and testing certificate. surely its better to ask this question on a forum rather than just go do a job if i am not 100 percent certain? after all it is a forum......
Quite correct Gregor.
It's just we get a lot of DIYers trying it on. If you'd explained a bit more in your first post you would have had different answers.
Still, welcome along.:D
And then someone lies on an EIC saying that they were responsible for the design, installation and I&T - and they've probably never been near the job.:)
Great this large-firm/competent person loophole, isn't it.
Personally, I think an electrician should be responsible for I&T on all his own work, it's part of the job, instead of this fast-track method.
I'm curious,
Once the 'Rewire Squad' have been in and done the rewire/CU change, do the 'testers' then go in and dismantle everything again, to do the testing correctly.......you know - 'Continuity of Ring Final', R1 + R2 etc??:)
can't see 'em pulling the CU wiring apart to test properly
Reply to fuseboard change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a fuseboard change I need to do soon I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD My only concern is how I should run the pyro cables in...
Evening everyone… I’ve attached pictures for your leisure.. so basically the customer does not have any RCD protection.. 3036 fuseboard is in...
Hi, I have just replaced an old rewireable fuseboard with a 10way consumer unit with rcbo's fitted. The issue i have is that when i connect one of...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
