Discuss Generation meter position for multiple inverter installs. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
gr7
I have 2x inverter domestic installation and need some advice on the meter position.
In order to meter generation from both inverters, and both inverters needing a separate MCB, I need to place the meter before a 2 way CU. Would the correct approach to be take tails directly from a henley block to the generation meter, then from the meter to a dedicated 2 way dedicated CU.
What do others do on these jobs?
We would put an isolator between the henley block and the gen meter, then the dedicated cu, then two isolators (one each) etc..
Reply to Generation meter position for multiple inverter installs. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hello everyone, I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
