Discuss Generator Connection in the UK Electrical Forum area at ElectriciansForums.net
Eickecc
Hi - looking for some guidance for my off-the-grid cabin.
I’m powering the main panel with 30amp generator plug. What wire do I use from the 30amp inlet plug to the main service for the panel? 10/3?
Also, I’m on bedrock and cannot drive a grounding rod into soil. How can I ground the panel? Thanks!
How far down before you hit bedrock?
Sometimes you can get away with laying your electrode horizontal, if you get down far enough.
And you should ground your generator too. The electrodes will have to be at least 6' from each other as well.
Get you a hammer drill and bore holes in to the bedrock for your grounding electrode. Since you are off grid, anything kind of metal will work. I seen a picture of a car hood in the ground for their grounding electrode. Get creative
Reply to Generator Connection in the UK Electrical Forum area at ElectriciansForums.net
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hello, First of all, thank you in advance for any helpful insights posted in response to my question. I have just moved into a new home. With...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I have a professionally installed Generator Interlock on my 200amp load center in my 1-family residence here in the US. I have 10 gauge wire from...
