Discuss Height of sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
sparky1966
Hi again,
I know that the regs say that sockets need to be a minimum of 450mm from the floor, but if you are adding a socket to an exsisting room does it still have to be that minimum height as it would obviously look out of place with the others.
Can anyone help please.
Hi Hawk81
So if the aditional sockets are in a room which has been extended from the original room is that still correct. Or is the new part of the room counted as a new build?
Hi Hawk81
As it's forming part of the original installation, keep them at the same height as the existing sockets.
Does anyone have the reg number from the BS 7671-2008 giving us the minimum heights of 400mm for sockets or that they can't be fitted to a skirting board ..................just be nice to quote it if ever needed.
It's not in BS7671, it's a building reg for new build properties. There's a bit in the onsite guide on the subject if that's any use.
Put them at the height of the existing ones. Common sense needed here. When wiring an extension I always put accessories at same height as the rest of the house.
it is not about BS, it is about visual sense. you dont need to be prof. to know that it will look ugly if you put them at different heights. unless ofcourse if it is better financially for you to uninstall all previous sockets and install the new ones, then you can blame the bs and say hey the code says it should be 400mm who am i to judge the code.
Did a new build recently and the customer wanted the sockets low. All I did was make provision for them to be easily shifted should the need arise and noted accordingly on the cert...........
Hight Levels are crap and people know it....! yeah ok mrs jones cant reach her CU to reset the RCD from her wheelchair but Mr Smiths can easily poke there fingers into his CU...
Reg. No. 553.1.6 "A socket-outlet on a wall or similar structure shall be mounted at a height above the floor or any working surface to minimize the risk of mechanical damage to the socket-outlet or to an associated plug and it's flexible cord which might be caused during insertion, use or withdrawal of the plug."
What I have been led to believe,when trying to comply with the building regs
Existing installations, where there are additions or even rewiring, where major renovation work has not been carried out
Switch + socket heights can match the original, as long as the contravention of the building reg is not made worse
The switches cannot go higher and the sockets cannot go lower than original heights
This was pretty much understanding too, the deviation from the "new" heights being allowed because of the existing sockets.
That said I thought you either had to put them at the same height or at the new height, not somewhere in between ;-)
I wish I could find the photograph I took of a relatives house. They had an electrician in a while ago to add two sockets in the lounge - the electrician insisted the new heights were law and they couldn't have them at the same height as the existing sockets - made for a very odd looking wall!
Reply to Height of sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
