Discuss Help and advice needed for wiring new lights in attic in the DIY Electrical Advice area at ElectriciansForums.net
H
henrig24
Ok, so I have made a diagram off the current set up in my attic for the current installation
a pretty simple connection
Now, I am not sure at all if this would be a correct / safe way of doing this, but I have removed the current light and replaced it with a 4 way 10amp junction box and I wish to connect three lights to this box.
Here is my diagram
I have created another diagram of my new set up.. I have labelled the terminals by number and I just need someone to clarify which wires I need to join to which terminals (that is assuming this set up is correct!0
Thanks for help in advance.. Henri
bad idea as each terminal will have 4 wires in it. a poor connection is likely. better to wire from switch to light 1, then loop to light 2, then to 3.
Tel's idea is the best arrangement.
However as you have said you have a 4 way junction box but have shown 8 terminals presumably 1 and 2 are connected together, and 3 and 4, and 5 and 6, and 7 and 8, in which case you can put two cables into each terminal and the join between the two terminals means the circuit is maintained.
If the terminals are not joined then you could put a link wire between the two terminals and then only have three wires per terminal.
Reply to Help and advice needed for wiring new lights in attic in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello, I'm new to this and I'm looking for someone to review my wiring diagram. I'm not sure if I need a fuse block because I'm using an XTM...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
