Discuss help with motor in the Industrial Electricians' Talk area at ElectriciansForums.net
James
Mentor
Supporter
Patron
anyone able to help me with this motor?
its a dc motor with forced vent.
i am trying to find a suitable motor drive for it but the nameplate is confusing me.
anyone fancy deciphering it for me?
From what I found out online the G and N mean direct current, shunt. The A is to do with ventilation, the rest no idea. Try contacting Baumueller.
Armature voltage, current, power, speed self explanatory.
Shunt wound. Err. = Erregung = excitation, 190V 2.8A
Schwinggüte SR = vibration class SR but I can't recall which EN this relates to.
so
130-400v is that a range? I am used to seeing max voltage shown on nameplate but never a minimum.
94-94 in A box is max current for any voltage?
suggests to me that the obscured part should read 10-34Kw
thanks for the err. didn't know that was the excitation voltage, but it makes sense now you have pointed it out.
[automerge]1582833001[/automerge]
basically it looks like a standard 3 phase 2 or 4 quadrant drive rated for 100A should suffice.
Thanks for everybody's input.
Yes, 94A at any armature voltage in the range 130-400V. i.e. constant max torque over 10-34kW output. I think the point with the minimum voltage is that the minimum rated speed (possibly specified by the machine makers) is 1000 rpm, and that is the voltage needed to achieve that speed. At lower speeds it might fall out of spec for torsional vibration etc.
Reply to help with motor in the Industrial Electricians' Talk area at ElectriciansForums.net
hello guys i have a (3-6v dc motor), (DC Motor PWM Speed Controller 3V 6V 12V 24V 35V), (3.7v 1200mah rechargeable battery) and a (Charging /...
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
I'm working on a robotics project and currently we are designing a battery. This battery is dedicated to the motor driver and two BLDC motors. I...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
Hello, I need to understand whether a DC motor is sturdy or not. The support person told me to measure the armature and field winding resistance...
