L
linux44
Hi all
I am very confuaed trying to fix my horn
I have an omp aftermarket wheel which has a red connector attached to the Hub metal bit and available as spade connector to connet to the horn button
Then the horn has two tabs for spade connectors which are ground and positive
Ground is making contact with a hub using a little latch on the back of the horn button so you don't have to wire it
I have a relay which has direct power and ground from battery, a leg going to horn and a leg to the switch which is plugged to the horn button on the hub
This doesn't work however if I touch the horn red wire previously plugged to wheel positive connector the horn works
What am i doing wrong here?
on relay,
30 to live positive direct feed
85 ground direct feed
87 to horn
86 to back of the hub which is grounded but has no other power going to it
horn is then grounded
on relay,
87 to horn
