Discuss How best to wire this light fitting? in the DIY Electrical Advice area at ElectriciansForums.net
leew85
Good afternoon guys, got a new light fitting, which is not supplied with the usual female terminals for wiring but rather has a short wire permanently attached. I know many people would just connect the cable with a choc block or wago, perhaps wrap it in tape and then just shove it through the hole in the ceiling but I believe that is bad practice and I want to do this properly. I would rather not have to lift the boarding and insulation in the attic and would also rather avoid cutting an large hole in the ceiling. So wondering that is a good way (if it's possible) of doing this which is safe and compliant?
Thanks, lee.
If you already have cables in situ from the ceiling then that is as good as useless unless you fit a joint box on the ceiling.
Reply to How best to wire this light fitting? in the DIY Electrical Advice area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
