Discuss How do I determine the current needed for my truck's wiring harness? in the Auto Electrician Forum area at ElectriciansForums.net
Howdy, y'all, new member here. I'm making a new engine harness from scratch and I'm a bit confused by how much current capacity I need my truck's wiring harness to have. Based on the fuse ratings, it needs to be able to handle 210A but that doesn't make sense to me because that would be about 7 10AWG wires and, from what I could tell, the older wiring harness only had about 3 10AWG wires. I haven't been able to find any information to explain this large difference in current capacity and I'm wondering if I'm missing something obvious. The fuses are listed below with the fuse ratings given by the truck's fuse box. If someone could set me straight, I would greatly appreciate it.
ItemTypeCurrent (A)Hot When
Stop/Hazard LampsFuse15All Times
Power Door LocksFuse30All Times
Horn; Cigar LighterFuse30All Times
Turn Lamps; Backup LampsFuse15Accy
A/C-HeaterFuse30Accy
HeadlightsFuse15Accy
Power WindowsFuse30Accy
IGNBreaker10All Times
FUELBreaker5All Times
STARTBreaker30All Times
Wiring sizes are not same as a house, in the UK where I live we seem to select wire sizes depending on use not fuse size, but since we use different class for wire size, can't help with US wire guages.
Reply to How do I determine the current needed for my truck's wiring harness? in the Auto Electrician Forum area at ElectriciansForums.net
Hello! My shop is currently on a single 15 amp circuit. Is like to upgrade it at the main home panel to a 30 amp. Do I just need to run 10 gauge...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Homeowner here, working on my fish pond power supply. (Fish pond came with the house and I'm wanting to update.) Currently 220v comes off of a 2...
