Discuss How do I wire this confusing light switch? in the DIY Electrical Advice area at ElectriciansForums.net
nwhoran
So I had a malfunctioning single gang switch in my garage and opened up the box to find 3 wires:
1 black red earth - seems to be providing power
2 yellow blue red - which is the circuit for the garage switches
3 yellow blue red - which is somehow sending power to the upstairs bathroom
Not come across this before so would value input on the best approach to wiring it
Do you have a picture of how it is actually connected at the moment?
Yeah the photo is a bit confusing so I've updated my dodgy schematic. I've only just moved in, the bathroom lights seem to be working fine but the garage switches aren't controlling anything and the lights are flickering. Something not quite right but struggling to get my head around it!
At a guess, the t&e cable you marked as power is live and switched live from the light fitting, and the live and neutral feed will be at the fitting.
Are you able to post a picture of the wires at the garage light?
Hi Timbo, this is what it looks like at the light
I think there must be a junction box (or more than one) somewhere in between that lot.
You probably would be best getting a spark in to sort it out. If you post your location, there may be a forum member near you able to help.
Reply to How do I wire this confusing light switch? in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
