Discuss I thought this would be simple........dimmer switch problems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
matty18714
Hi all,
I am trying to do a simple plug-dimmer-bulb sort of thing but I'm struggling and starting to pull my hair out! I've got a normal plug with a 13 amp fuse, a dimmer switch that says "216-253v - 50hz, max load 250W, min load 40W", and both a bayonet and ES bulb fitting.
The dimmer has 3 connections - L1, L2 and C. As far as I can work out I don't need L2 for what I'm trying to do.
So, at the moment I have wired the plug, stripped a section of the flex half way along with the live snipped and stripped, and fitted the bayonet fitting with bulb at the other end.*I want to put the dimmer in the stripped area so I have connected the live wires to the dimmer in every possible combination but I cant get the bulb to dim! It will go on and off but not dim.
So, what am I doing wrong?
Thanks,
Matt
Ok. I've just wired it like that and it will turn on and off but not dim. When I first plugged it in with the dimmer wired in I had a 3amp fuse in the plug which went a second after switching it on. Is that likely to have damaged the dimmer?
Yes, very likely blown the dimmer.
Dimmers can fail in two ways, they either go completely open circuit in which case the lamp won't light at all or they go completely short circuit in which case the lamp will only be on at full brightness. Either way it's time for a new dimmer I'm afraid.
Remember, don't put a neutral on the dimmer, it only gets a live in and a switched (dimmed) live out to the lamp (bulb) holder. The neutral goes directly to the other terminal on the lamp holder.
Reply to I thought this would be simple........dimmer switch problems in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
Hello! I design and build lamps, which has been a simple task so far, but I've decided to dip my toe into the dubious world of 120v LED PCBs for...
Hello everyone. Thank you in advance for any help you can provide. I tried installing a dimmer to a 3-way circuit. The dimmer has a hard...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Good afternoon, I wonder if someone could please give me some advice on a problem I am having with my bedroom lights. I have replaced the...
