darren
Hi guys i have a few questions and would be great if someone could advise. Reason I'm asking is because of a difference of opinion between myself and another sparks, my answers are in grey (If I am wrong then my excuse is its been a year since I left college and all i have been doing since is social housing re-wires!!!)
All questions are relating to commercial work
First question - If installing a new circuit into a spare way in an existing board does the entire installation require testing or is a installation certificate adequate?
Install Cert
Second question - if I was to down rate say a 32A to a 20A and re-use the feed cable but replace the equipment is a installation certificate adequate or would this require a full test.
Install Cert
Third question - Is commercial work notifiable?
No unless property is sharing a meter with domestic
Fourth Question - before installing a new cct its noticed that the the main bonding is not up to scratch, can we continue without rectifying?
No
Fifth Question - before altering a cct its noticed that the the main bonding is not up to scratch, can we continue without rectifying?
No
Thanks in advanced guys and gals!!
oops wrong section??...i think..... sorry!! could someone move this please!
Install Cert....
EIC...with a full test on the work you have carried out,not the entire installation
Install Cert
Same as above.
No...you are correct.Part P is domestic only.
No
Depends on an assessment of the risk,if it is not sized to the current regulations but shows no signs of overheating the designer may deem it adequate.Generally though main bonding should be upgraded.
No
Same as above
Installation cert or periodic? plus a few other questions
darren,
darren,
