Discuss Installing time lag switch on a boiler in the DIY Electrical Advice area at ElectriciansForums.net
J
Jayworth
Hi there,
Long time forum browser here and I've now been stumped and need some expert info that I haven't been able to find so far
i am wondering if it is possible to add a time lag type switch (like the ones uses for lights) for the boiler circuit so that whenever it's pushed the boiler, be it heat or water, is active for X number of minutes or hours, and then turns off. The button would have to be pushed again to turn it on.
The reason for this is I have a rental property and the tenants are constantly leaving the boiler heating on high when they are out (I pay the bills). Additionally the boiler (ideal Isar he24) turns on for about 5 minutes every half hour to keep the water up to temperature thus using lots of gas.
I really want to reduce/stop the boiler heating up for the water every 30 mins as it's really not needed and just wasting gas, and have the boiler turn off after X minutes or hours so that of the tenants go out it's not wasting fuel!
any ideas?
Thanks, Jay
The way you describe using a time lag switch, the boiler / heater would hardly get up to any decent temp before you needed to push the button again, probably do a lot of damage being constantly switched on and off, maybe a time clock would be better, a qualified Electrician could assess the problem for you I would think
What controls does the system have at the moment? Is it a combi boiler, or does it use a hot water cylinder (if the latter then a cylinder stat should stop or much reduce idle firing for water).
Reply to Installing time lag switch on a boiler in the DIY Electrical Advice area at ElectriciansForums.net
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
