Discuss Is it possible to use 1 switch to control dimmable LEDs as well as a ceiling fan and non-dimmable strip LEDs? in the UK Electrical Forum area at ElectriciansForums.net
When you say 1 switch do you mean 1 switch or 1 switch plate with 2 switches and 1 dimmer? Have you got cabling in to all 3 circuits back to the switch position?
So long (of course) that all three are on the same circuit (presumed to be a lighting circuit).
As above if your happy to not dim the dimmable leds then you can. If you do want to dim the dimmable leds you will need a click mode 2 gang switch and swap 1 switch for a click mode led dimmer module.
Welcome to the forum mate
All depends on what you actually want to do.
If all you want to do is turn on all 3 items with the 1 switch, then as above, a standard On/Off switch will do this. Of course you would not be able to dim the dimmable LEDs. They would just be on or off.
If you want to dim the dimmable LEDs and switch the fan and non-dimmable LEDs on then you can't do this with a standard dimmer switch or On/Off switch.
You may be able to use a dimmer switch and add additional equipment (like this) to the fan and non-dimmable LEDs circuits that could detect the sign wave of the dimmer and then switch on fully. I'd have to test this to see if it works correctly though. The relay may not like a chopped sign wave. This would also involve extra wiring.
Reply to Is it possible to use 1 switch to control dimmable LEDs as well as a ceiling fan and non-dimmable strip LEDs? in the UK Electrical Forum area at ElectriciansForums.net
I'm looking for a floodlight (preferably 50w), that can be dimmable with a standard led dimmer switch (probably a varilight v-pro). All I can...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
